Bantam New Build
john b
Just completed a bantam new build. Started with a 4 speed engine and heavyweight forks bought cheap off a lad at work. Frame kit from progressive classics, bantam hubs with new akront rims, everything else new or newly manufactured. Was it cheap ? Probably about £2500 without all of my dads labour or many "guvvys" from work but I think worth it and looks good. First try out tomorrow . Any opinions ?
Cheers
John
  • Like 8
Thanks Deryk ! Im no photographerso thanks for the advice !
Yes its for Chris as his pre65 ride
hes doing really well on the twinshocks, this engine came up so decided to buikd a competitive bike for him whilst hopefully keeping it as true to pre 65 as posdible
cheers
John
Hi there
I just coudnt get it to run right with the amal so tried the mikuni. I had added a spacer between the barrel and carb so that may have made it run better anyway. Once Ive tried it,I may put the amal back on to see hoe it goes
thanks for tne comments
cheers
John
  • Like 2
the magic of the bantam is that no two ever have the same jets/slide.. i really must say though that once dialled in they can be better than perfect.. worth the investment of the su carby and a complete set of jets.. i did and experimented for probably 9 months till it ran like a watch and power came like pouring cream..
  • Like 2
cheers
John
Hi John,
I like it, looks really nice, where did you get the alloy tail pipe/silencer from.
I had same trouble getting mine to run nice, ended up with a new Amal in the end, despite none of the secondhand one that i overhauled looking that bad or worn.
which ignition did you choose?
Hi there
The silencer wad an ebay purchase. Not sure what it was off but was almost brand new. Volume of the silencer was the same as a friend of mines who I measured, so I has the inlet modified to take the bantam front pipe which i had angled to suit.Sounds nice and seems to run well.
Cheers
John
not often I like the trend for old modern trick bikes but I must admit I like your one I only have one question , I was taught that to get the ultimate carburation you should have a airbox of at least twice the volume of air that the motor needed before the filter as such all of the off road bikes that I have built over the years have been fitted this way with the largest air box I could fit in ,am I missing something or were the expert guys who taught me over 50 years ago wrong
Hi there
I did contemplate an aluminium airbox with a beta style filter , but favours at work to make it are a little thin at the moment so maybe later. A lot of bantams I see have the foam filter so decided to go with that. It does sound like it sucks a lot of air when you open the throttle but runs ok. Originally I planned 40mm ducting to take the filter up under the seat (hence the cut out in side panel) but the ducting was just not strong enough. I've ordered a bultaco Sherpa filter today with a cranked inlet hose which should tuck it further in. Thanks for all comments ! And Deryk, I've told Chris he needs to keep an eye out !
Cheers
John
the theory is that to get instant throttle responce you need a lot of clean filtered air at least twice what the motor cosumes on a full throttle attack ,i cannot see how sucking air through a foam filter without can do the carburationany favours ,i have home made airboxes on both of my greeves outfits including one of the last factory bikes both run on std amal mk1 carbs with probably the cleanest caburation i have ever had, i
Got any pictures of these airboxes? Reading this has given me ideas for my TFS. At present it has a Villiers air filter with a home made adapter to fit the amal concentric on the bike.
