What Do You Think Of This 2006 Gas Gas Txt 250 Pro?
thesaint
I am thinking of buying the 2006 Gas Gas TXT 250 since it has an okay price and the bike looks to be very well cared for
The bike have just been joy rided and not used in competitions
The bike have almost not been in use the last years but it have been started now and then
I would check the dog bones, bottom of frame, skidplate, etc. Are they all bashed in?
The skid plate looks to be pretty flat from the second picture. It comes stock with a "V" bend near the back mount. Also make sure the rubber is underneath the rear mount.  I'm replacing my bashplate b/c it is so bend up.
Only so much we can tell from photos (good eye Lineaway on the clutch cable routing). If there is gear box fluid is it milky colored? If so that is water pump rebuild time.
Overall looks pretty clean though. Hope it works out for you.
Are those black forks off of a newer model 2008?? If your really not sure what to look at, maybe ask the owner to meet you at a local trials shop and flip them a few $$ to give it a quick once over for you??
The black forks are normal, they were fitted to the 2006 models.
