toetoe Posted August 24, 2016 Report Share Posted August 24, 2016 Iv got a very small leek, it's coming from the clutch cover so I thought the first thing to try is the gasket, that's coming tomorrow so I decided to get my bike ready, I have tried to get the kick start off but it will not budge, is there any tips you could suggest, my bike is 2013, thanks. Quote Link to comment Share on other sites More sharing options...
zippy Posted August 24, 2016 Report Share Posted August 24, 2016 use the bolt as a pry point. loosen the bolt a few threads so that it sticks out a little bit. then take the kickstarter and "open it up" like you would to start the bike. the kickstart lever will contact the bolt and "pull" itself off the shaft. Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 25, 2016 Report Share Posted August 25, 2016 It`s either the gasket or the kickstart seal. The seal sometimes gets pushed out. After you get the KS off the shaft, try using a socket to seat the seal again. 1 Quote Link to comment Share on other sites More sharing options...
