How To Remove Txt320 Fork Seals?
mechanic
I currently have a tired old Gasgas JTX 320 ('97 I think) awaiting the installation of new fork seals.
I cannot unscrew the upper sleeve on the slider, due to either the two parts being time fused together, or simply not being able to get enough torque to break the threads. I can find no data on this particular fork on the internet. I would normally remove seals by first taking out the dust seal. Remove the circlip above the main seal. Remove the bolt in the  bottom of the leg, and then sliding the stantion and slider apart with a brisk tug or two.
That is simply not working with the Gasgas leg. Am I missing something? Can someone advise me of the correct procedure if I've missed something and better yet, ink em to a pdf or other document that pertains to the said model.
Thanks in anticipation of some help.
Paul (Mechanic)
