Tickover Affected By Fan
anotherfive
Obviously, both are entirely possible
The electrical energy needed to run the fan increases the load on the alternator / engine and drags the tickover down a little
If the output of the alternator at tickover is less than 12v then the fan will run slow, increasing the alternator / engine rpm and thus the voltage will increase the fan rpm
