andyjohnson_10850 Posted August 30, 2016 Report Share Posted August 30, 2016 anyone of you good Fellowes fitted a flywheel weight to a 250 trs , can you fit one ?? had a peek behind my cover and it looks a bit special in there cheers andy Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted August 30, 2016 Report Share Posted August 30, 2016 Does it need one, is it a bit too responsive to the throttle? Quote Link to comment Share on other sites More sharing options...
andyjohnson_10850 Posted September 7, 2016 Author Report Share Posted September 7, 2016 i think it may do to suit my sh*t riding style ! i have a slow throttle which helps but just a little more help would be good. its probably not going to happen as the flywheel is an inverted type , so is not easy to bolt one on ! Quote Link to comment Share on other sites More sharing options...
neils on wheels Posted September 8, 2016 Report Share Posted September 8, 2016 Have you asked Steve Saunders? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 12, 2016 Report Share Posted September 12, 2016 I think the TRS has a "crankshaft" bearing in the flywheel case. This may make fitting a weight a bit trickier than usual. Lower compression? Smaller bore carb? Reduce the diameter of the exhaust either at the engine or tailpipe using an insert? Quote Link to comment Share on other sites More sharing options...
andyjohnson_10850 Posted February 2, 2017 Author Report Share Posted February 2, 2017 No u can't fit a flywheel weight ! I just got used to riding it ! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted February 2, 2017 Report Share Posted February 2, 2017 Fit two Base gaskets might help 1 Quote Link to comment Share on other sites More sharing options...
sting32 Posted March 22, 2018 Report Share Posted March 22, 2018 The vertigo has essentially the same "design" at least at the flywheel, and someone makes a light and heavy flywheel weight for those bikes. Maybe soon they will make them for the TRS or something. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 11, 2018 Report Share Posted August 11, 2018 flywheel weight will make it run on, i think this can be a disadvatage for a novice. Quote Link to comment Share on other sites More sharing options...
