Cub Kickstart
vinnied
  • 1 month later...
I too am having difficulty obtaining a Cub splined kickstart assembly but lots of people seem to have fitted a Gas Gas kickstart to their Cubs, how do they get them to fit, does it need,
the Cub kickstart shaft splines (assuming you have one in the first place) altering to suit the GG lever
the GG lever altering to suit the Cub splines
is there another way ?
Why not just stay with the cotter pin type all the bits are readily available and this system is used on many other bikes & has been used to propel thousands of bicycles along for years.
Does anyone know how to fit the GG lever to a Cub.
Araldite is always the sticky stuff of choice, heat and oil resitant the best use I ever had for it was sealing a compltely corroded water channel on a vintage car cylinder block, 2 days work layering it up gradually and it never leaked a drop after
have I told you how to mix the petrol tank sealant that involves Black treacle and it really works..
  • 1 month later...
To fit Gas Gas kickstart:-
The flat on kickstart shaft that takes normal cotter pin needs to be groung back carefully with a hand grinder so the flat now comes right to the end of the shaft, now ream out the steel swivel of the Gas Gas kickstart so its a nice fit on shaft then from a piece of round bar cut a d shaped piece that fits the d shapes space that remains when you have fitted the kick start swivel on to the now reground kickstart shaft, make sure you have it positioned in the right place and then weld this new d shaped piece in place in the kickstart swivel.
Now a bit of pub, we make half hard ali kickstarts for cubs along with our new
wide ali forged footrest/ali mounting brakets that take ali brake lever and ali chain tensioner.....
PS, What is best is to use a dummy kickstart shaft in a vice, to be sure you've got it all set up/dimensionaly correct and it can then be checked at itervals so your not making a cock up.....Gas Gas kickstarts are not cheap and all this work while not complicated needs to be done well/acurately.......
STU what can i say B)
First class :)
  • 1 year later...
