moulder Posted September 6, 2016 Report Share Posted September 6, 2016 Hi, 03 SY250 Trying to remove the water pump impeller in order to remove the RHS engine case to inspect the clutch. Does the impeller pull off with the Case? I do not want to simply pull the impellor out if it's fixed behind the case etc and potentially break something . I can only assume that the impeller & shaft assemble can be pulled out with some pliers or the impeller is attached to the shafts with a LH thread? Either way do I pull the impellor off with the Case or am I missing something? The impeller appears to be the only thing holding case on now that I have removed the bolts, kick-start & water pump case. Cheers Tony Quote Link to comment Share on other sites More sharing options...
144hound Posted September 7, 2016 Report Share Posted September 7, 2016 Been looking how to do this recently as I think my seal on the impeller is leaking. From what I understand it should just come off with the case, and is held on behind with a nut on the end of the spline. I'm going to do my seal at the weekend do will let you know if it's any different, BTW if you search thehellteam, you can find the full scorpa engine manual on that site, GL ? Quote Link to comment Share on other sites More sharing options...
144hound Posted September 8, 2016 Report Share Posted September 8, 2016 Actually ended up doing it last night, it's attached to the case and held in place with a circlip and a small dowl through the shaft, On a slightly different note that water seal was a nightmare to hook out, took me about an hour before it surrendered Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted September 16, 2016 Report Share Posted September 16, 2016 They are a bear to remove. So I made the Mrs do it since its her bike anyway. we basically used a screw in the seal and pried it out. --Biff Quote Link to comment Share on other sites More sharing options...
moulder Posted September 26, 2016 Author Report Share Posted September 26, 2016 Cheers for the help. Pumps now off. Quote Link to comment Share on other sites More sharing options...
