Scorpa Sy250 Water Pump Expeller Remval
moulder
Trying to remove the water pump impeller in order to remove the RHS engine case to inspect the clutch. Does the impeller pull off with the Case? I do not want to simply pull the impellor out if it's fixed behind the case etc and potentially break something . I can only assume that the impeller & shaft assemble can be pulled out with some pliers or the impeller is attached to the shafts with a LH thread? Either way do I pull the impellor off with the Case or am I missing something? The impeller appears to be the only thing holding case on now that I have removed the bolts, kick-start & water pump case.
Cheers
Tony
