chris200 Posted September 10, 2016 Report Share Posted September 10, 2016 What options are currently available and does the year of manufacture matter ? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted September 10, 2016 Report Share Posted September 10, 2016 Considering the importance of good working suspension and the quality and longevity of the Honda\Montesa bearings in comparison to most of the alternatives I say stick with stock. FYI, the first owner of my bike got a set of the All-Balls and told me it was so loose it was like running the old stock ones so he went back to stock and it was worth it. My 2 cents. good luck. Quote Link to comment Share on other sites More sharing options...
guys Posted September 10, 2016 Report Share Posted September 10, 2016 Considering the importance of good working suspension and the quality and longevity of the Honda\Montesa bearings in comparison to most of the alternatives I say stick with stock. FYI, the first owner of my bike got a set of the All-Balls and told me it was so loose it was like running the old stock ones so he went back to stock and it was worth it. My 2 cents. good luck. +1 Quote Link to comment Share on other sites More sharing options...
basil Posted September 10, 2016 Report Share Posted September 10, 2016 Ditto the above I tried both and my preference Montesa oe every time Viva Montesa Quote Link to comment Share on other sites More sharing options...
scottj Posted September 10, 2016 Report Share Posted September 10, 2016 For what it's worth, I've had good results with All-Balls. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 10, 2016 Report Share Posted September 10, 2016 You local bearing/seal stockist will have good quality items at a good price. Get the genuine bushes though, as some aftermarket ones are made of the same cheese as the sump guards. Bearing size 15×21×12 seal size 15×21×3. Quote Link to comment Share on other sites More sharing options...
chris200 Posted September 11, 2016 Author Report Share Posted September 11, 2016 (edited) You local bearing/seal stockist will have good quality items at a good price. Get the genuine bushes though, as some aftermarket ones are made of the same cheese as the sump guards. Bearing size 15×21×12 seal size 15×21×3. I know that is the size for the early models but I have read somewhere that 2008 onwards use something like 14x22x12 to slightly increase the bearing roller size ???? I've only got the 2005 parts list so can't check for my 08' Edit . All Balls only list up to 2007 so it looks likely that there is a difference Has anyone tried something like http://www.ebay.co.uk/itm/15x21x12-mm-JDB-Graphite-Lubricating-Brass-Bearing-Bushing-Sleeve-Choose-Qty-/272144327603?var=&hash=item3f5d10e3b3:m:mIoTdnWNIUnRuPt-fyyb5Pg or http://www.ebay.co.uk/itm/15x21x10-mm-JDB-Graphite-Lubricating-Brass-Bearing-Bushing-Sleeve-Choose-Qty-/272144327681?var=&hash=item3f5d10e401:m:mIoTdnWNIUnRuPt-fyyb5Pg which are narrower and would allow a grease nipple to fit between the bearings . Edited September 11, 2016 by chris200 Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 11, 2016 Report Share Posted September 11, 2016 I haven't been aware of any change, the 15x21x12s have been going in my 2012 bike every year. Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted September 12, 2016 Report Share Posted September 12, 2016 (edited) I know that is the size for the early models but I have read somewhere that 2008 onwards use something like 14x22x12 to slightly increase the bearing roller size ... The 2005, 2007, 2009, 2012, 2014, and 2016 parts lists all show the same PN for this bearing -- 91071-NN1-000 BEARING, NEEDLE 15X21X12. They were also used in the 315R. Edited September 12, 2016 by sportsawyer 2 Quote Link to comment Share on other sites More sharing options...
guys Posted September 12, 2016 Report Share Posted September 12, 2016 I know that is the size for the early models but I have read somewhere that 2008 onwards use something like 14x22x12 to slightly increase the bearing roller size ???? I've only got the 2005 parts list so can't check for my 08' Edit . All Balls only list up to 2007 so it looks likely that there is a difference Has anyone tried something like http://www.ebay.co.uk/itm/15x21x12-mm-JDB-Graphite-Lubricating-Brass-Bearing-Bushing-Sleeve-Choose-Qty-/272144327603?var=&hash=item3f5d10e3b3:m:mIoTdnWNIUnRuPt-fyyb5Pg or http://www.ebay.co.uk/itm/15x21x10-mm-JDB-Graphite-Lubricating-Brass-Bearing-Bushing-Sleeve-Choose-Qty-/272144327681?var=&hash=item3f5d10e401:m:mIoTdnWNIUnRuPt-fyyb5Pg which are narrower and would allow a grease nipple to fit between the bearings . Parts list can be found under Documentation: http://montesa4rt.nl/ Why don't you test those graphite brass bushings and let us know the result? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted September 12, 2016 Report Share Posted September 12, 2016 You local bearing/seal stockist will have good quality items at a good price. Get the genuine bushes though, as some aftermarket ones are made of the same cheese as the sump guards. Bearing size 15×21×12 seal size 15×21×3. FYI -you can get two types of needle roller bearings -some have an internal cage and some have no cage but extra needle -these are classed as full compliment needle rollers as I recall and are what are fitted as std. You can fit either but the full compliment ones last longer as the loading is spread over a greater area -they are more expensive though. Quote Link to comment Share on other sites More sharing options...
chris200 Posted September 12, 2016 Author Report Share Posted September 12, 2016 Parts list can be found under Documentation: http://montesa4rt.nl/ Why don't you test those graphite brass bushings and let us know the result? Thanks for the link which has confirmed the size , The bushes have been ordered and I will report back 2 Quote Link to comment Share on other sites More sharing options...
