Beta Evo Pinking
beta200290
Try regular octane fuel to speed up the combustion. What you have may not be usual pinking. At low RPM in a big cylinder with soft / retarded mapping the burn can be slow and incomplete when the next new fuel air charge enters the cylinder, this causes sort of "bonging" and uneven running not unlike pinking. Squish clearance may need checking.
EDIT - If you are running a lean oil mix and your piston / rings / bore is worn you could be getting blowby into the crank case contaminating the new incoming charge. This can cause the similar symptoms
Edited by dadof2
Could be air leak. A friend's EVO blew out the case gasket below reed housing due to loose case bolt. Of course check timing and carb. Kehins are notorious for blockages in the piddly little bleed cirrcuit behind the slide.
Edited by dan williams
