t20racerman Posted September 22, 2016 Report Share Posted September 22, 2016 Hi all I'm restoring a TR77 that I was given as a box of bits (and so have no knowledge of set up...). My Clymer manual tells me that the Ossa has electronic ignition, although the points and condensor set-up on my bike suggest otherwise! I've fitted new points and condensor and now need to set the points gap and timing. The back plate has a clear timing mark that lines up with the crankcasings, so I set it at this position. I then set the points gap to 15 thou, and this opened the points at around 2.2mm BTDC. I searched the internet and found suggestions of anywhere between 2 and 3.5mm BTDC, and a points gap of 40 thou seemed a common theme. So, what works best, or what is a good starting point for both the points gap and the BTDC setting? Also, I have no idea which wire goes where! The Alternator/timing coils unit behind the flywheel has 4 wires coming out - Black, Green, Yellow, and a pale pink colour. Any info on which one does what would be welcome. I'm hoping to run a brake light and horn, without a battery - if anyone has done this, your advice welcome. :-) Thanks for your help Adrian Quote Link to comment Share on other sites More sharing options...
woody Posted September 22, 2016 Report Share Posted September 22, 2016 Timing is personal choice but yes, somewhere between 2 and 3.5 BTDC is the range most commonly used Can't help with points gap or wiring as never had a points ignition Ossa All MARs were fitted with electronic as were Grippers. For whatever reason the TR77 was fitted with points although a few may have had electronic. The MAR or Gripper electronic system will fit straight onto a TR77 as the engines are all the same. 1 Quote Link to comment Share on other sites More sharing options...
longlegscanbeuseful Posted September 23, 2016 Report Share Posted September 23, 2016 How is your Spanish..? Try here for manuals.... http://www.vitalemaquinas.com/manuales-despieces.html 1 Quote Link to comment Share on other sites More sharing options...
t20racerman Posted September 23, 2016 Author Report Share Posted September 23, 2016 How is your Spanish..? Try here for manuals.... http://www.vitalemaquinas.com/manuales-despieces.html Sadly not that good! :-) Quote Link to comment Share on other sites More sharing options...
