Piston Rings
creaser
Hi. I have a 2010 txt 300 pro raga which I am about to replace the main bearings. As the engine is apart I thought it may be a good idea to change the rings. My question is has my engine got a s3 piston fitted as standard. Also do you think it is a good idea to get the crank balanced while it is out. Thanks
