lotus54 Posted September 25, 2016 Report Share Posted September 25, 2016 (edited) I have a little 'burble' at very small throttle openings I only have ever had if the play was really knackered or the TPS needed reset. (Runs great everywhere else and mixture appears great on the plug- running SSDT Hard map) So I decided it would be a good time to just check everything anyway ((290 hours). Reeds good, new sparking plug Idle right, TPS set to .6V and set to EC Air filter clean Cleaned sensor in lower airbox I did see a little corrosion on the ECU connections (dang it!). Attempting to clean well. That could be my issue. BUT I wanted to test the injector to see what the pattern looked like. When I do the injector test in the software, it just clicks the injector, the fuel pump is not running so no fuel comes out. Any ideas? Mark Edited September 25, 2016 by lotus54 Quote Link to comment Share on other sites More sharing options...
axulsuv Posted September 25, 2016 Report Share Posted September 25, 2016 (edited) Wurth products makes a connector cleaner/lubricant that works great on small connectors . CRC makes a electronic parts cleaner that works good too . Sorry I don't know how the pump is controlled , but you may be able to power it up completely disconnected from the bikes wiring , To prevent any short back to the bike . And get your fuel pressure that way , or if there is a fuel pressure check mode , it should hold enough residual pressure to fire the injector one or two times if your quick .... Edited September 25, 2016 by axulsuv Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 26, 2016 Report Share Posted September 26, 2016 (edited) To test injectors I rig up a pressurised petrol supply (40 PSI) using a regulator, but a supply from a tyre inflated to 30 PSI plus should do. To supply the injector with electrical pulses I have an old model railway transformer that can supply AC or pulsed DC. I generally test at 25 Hz pulsed DC, starting at low voltage and turning it up until it is just sufficient to fire the injector. I would think tapping the wire on a battery terminal would work reasonably. Remember injectors are only meant to be fire for a few m/sec. Keeping the current on longer will trash them EDIT - remember electrical sparks + sprayed petrol = explosion Probably best to do test in garden. I only use a small volume of petrol, probably about 2 to 3 cc per injector. Edited September 26, 2016 by dadof2 Quote Link to comment Share on other sites More sharing options...
b40rt Posted September 27, 2016 Report Share Posted September 27, 2016 To test injectors I rig up a pressurised petrol supply (40 PSI) using a regulator, but a supply from a tyre inflated to 30 PSI plus should do. To supply the injector with electrical pulses I have an old model railway transformer that can supply AC or pulsed DC. I generally test at 25 Hz pulsed DC, starting at low voltage and turning it up until it is just sufficient to fire the injector. I would think tapping the wire on a battery terminal would work reasonably. Remember injectors are only meant to be fire for a few m/sec. Keeping the current on longer will trash them EDIT - remember electrical sparks + sprayed petrol = explosion Probably best to do test in garden. I only use a small volume of petrol, probably about 2 to 3 cc per injector. And having done all that, how do you identify a "burble" ? 1 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted September 27, 2016 Report Share Posted September 27, 2016 And having done all that, how do you identify a "burble" ? Don’t know about the burble, but you will find out how good your local fire brigade is 3 Quote Link to comment Share on other sites More sharing options...
trialtrial Posted October 14, 2016 Report Share Posted October 14, 2016 Here is a benchtop option for testing injectors and cleaning them at the same time. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted October 14, 2016 Report Share Posted October 14, 2016 And having done all that, how do you identify a "burble" ? You dont. You look for a consistent and uniform spray pattern. If it is not consistent and uniform, it will manifest itself into a poor running engine. Quote Link to comment Share on other sites More sharing options...
