diesel2607 Posted September 26, 2016 Report Share Posted September 26, 2016 I went out on my bike last night 2005 rev 3 and my back brake was binding and got very hot then lost brake altogether came home have bled brake by pumping oil in at the reservoir got a bit of a brake about 50% but only right at the bottom of the pedals travel any advice very helpful as riding this weekend Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 26, 2016 Report Share Posted September 26, 2016 Sounds like it needs a complete service. From your post I guess you are not an experience mechanic and not familiar with brakes. Have a good read on the Beta section of TC, there is lots of good advice. If you post your location you might be lucky and find someone local who could help. Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 27, 2016 Author Report Share Posted September 27, 2016 No your right not very experienced at all what would I need to do for a full service I am in Moray in North of Scotland how much would I be looking at to get the brakes serviced by a professional Quote Link to comment Share on other sites More sharing options...
technowaldo Posted September 27, 2016 Report Share Posted September 27, 2016 Just bite the bullet and buy a new master cylinder 80%of the time its the cylinder that's causing the bother not sure if the newer evo one with built in resevoir fits yours Quote Link to comment Share on other sites More sharing options...
petert Posted September 27, 2016 Report Share Posted September 27, 2016 If you hunt around like I did you may find a cheaper alternative master cylinder. I found that an Aprilia road bike (Brembo) one was the right size with holes in the right places for nearly half the price of the Beta one. £30 odd if I remember correctly Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 27, 2016 Author Report Share Posted September 27, 2016 How do you get the master cylinder off the bike Quote Link to comment Share on other sites More sharing options...
petert Posted September 27, 2016 Report Share Posted September 27, 2016 How do you get the master cylinder off the bike Undid the hose, undid the bolts that hold it to the frame Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 27, 2016 Author Report Share Posted September 27, 2016 OK thanks are the bolts that hold it to the frame pretty accessible or are there alot of things to take off first to get to it Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 27, 2016 Author Report Share Posted September 27, 2016 OK I have rear master cylinder off hiw would I know uf it's OK needs replacing or just needs a new seal kit any help is great Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 27, 2016 Report Share Posted September 27, 2016 Brake service by professional if no parts needed £40 to £60. Nearly always all brakes need is a strip, clean and new fluid. All the info is in past posts in Beta section. Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 28, 2016 Author Report Share Posted September 28, 2016 I got a quote of 42 an hours labour and guy didn't seem interested I am struggling to find places to do the work up here Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 28, 2016 Author Report Share Posted September 28, 2016 OK I have stripped the brake caliper off the bike and the pistons look like they are shot they won't move at all when I tried to pump them out could this have been caused by the brake overheating and do you think a caliper rebuild kit will solve the problems how much Is a new caliper I can't see my rear caliper anywhere Quote Link to comment Share on other sites More sharing options...
steve_earle Posted September 29, 2016 Report Share Posted September 29, 2016 If you have the two piston caliper then your bike has the Grimeca system, 4 piston is AJP brand. Trials and tribulations do the parts needed. The Grimeca caliper pistons are not very well anodized and wear very quickly. The rear master cylinders wear quickly inside, sometimes you can get away with just the seal kit. Phone Ian at Trials and Tribulations (google for number), He will send what you need. Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted September 30, 2016 Author Report Share Posted September 30, 2016 OK thanks ordered seals and pistons how do I know if I need to do the master cylinder Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted October 1, 2016 Author Report Share Posted October 1, 2016 OK so I have done pistons and seals got movement in the pistons and a half decent feeling brake but still not very strong can only just about lock up on wet grass when I throw my weight forward but the brake is working any further advice to get a good rear brake Quote Link to comment Share on other sites More sharing options...
