drumfada Posted September 27, 2016 Report Share Posted September 27, 2016 I have recently bought a Gas Gas 125, 2013 TXT pro which I am very happy with generally when it is running. My only issue is it is very hard to start. It can take 1/2 a dozen kicks sometimes. When it starts it revs really high for a few seconds and then dies down to normal. Once it has been running for a while and engine warmed up it starts easier but never first or second kick and needs the choke if stood for any length of time. I have changed plug, oil and cleaned filter and carb out, I also took flywheel cover off to check for water penetration and it was clean inside. I have ordered an NKG Iridium plug to see if that will help. Has anyone else experienced this with Gas Gas bikes and am I missing something fundamental. Quote Link to comment Share on other sites More sharing options...
petert Posted September 27, 2016 Report Share Posted September 27, 2016 Air leak somewhere? higher revs and choke required would indicate a weak mixture. What colour was the old plug? Quote Link to comment Share on other sites More sharing options...
drumfada Posted September 27, 2016 Author Report Share Posted September 27, 2016 Thanks for reply. I will recheck jubilee clip connections at Deloroto Carb. Old plug was blacker than normal( as opposed to tan colour) , I put that down to idling for a long time as I do not normally kill engine unless I am stopping for a long time. Quote Link to comment Share on other sites More sharing options...
petert Posted September 27, 2016 Report Share Posted September 27, 2016 Thanks for reply. I will recheck jubilee clip connections at Deloroto Carb. Old plug was blacker than normal( as opposed to tan colour) , I put that down to idling for a long time as I do not normally kill engine unless I am stopping for a long time. A black coloured plug would normally indicate a rich condition. Quote Link to comment Share on other sites More sharing options...
