allgoodfun Posted September 29, 2016 Report Share Posted September 29, 2016 Firstly apologies, i am useless with ignition systems, and this one is so simple !!I have a Honda TL125 hat was running, as i didnt have a stop switch fitted yet, and as i had a connection in th the black lead that comes out of the stator coil (?) (one on left of engine, i pulled it apart and the engine stopped. Then straight away connected it back up and no spark at all.Then after a bit of messing, connected the lead to the white one coming out of the stator coil (?) - it then started - i then put my hand over the carb to stop the bike - it now wont start on either connection and only occassionally has a spark when connected to the white lead.?What have i done ????? Quote Link to comment Share on other sites More sharing options...
allgoodfun Posted September 29, 2016 Author Report Share Posted September 29, 2016 Sorry also meant to say its used for trials and has no lights, battery etc ! Quote Link to comment Share on other sites More sharing options...
drgonzo Posted October 3, 2016 Report Share Posted October 3, 2016 I would start by getting a wiring diagram for that model TL125 and carefully trace all your connections. Make sure everything is connected as it should be and that the connections are clean and tight. Quote Link to comment Share on other sites More sharing options...
