monty_jon Posted September 29, 2016 Report Share Posted September 29, 2016 Will an early gasgas TXT rear wheel fit a later TXT Pro model? I’m after a replacement wheel, and I have found an earlier one for sale at the right money! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 29, 2016 Report Share Posted September 29, 2016 Depends on year. It's got to have the caliper inside the swung arm like the pro rather than above Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 29, 2016 Report Share Posted September 29, 2016 are the last 3 years not different? Quote Link to comment Share on other sites More sharing options...
monty_jon Posted September 29, 2016 Author Report Share Posted September 29, 2016 Thank you for the help , I'll keep looking for a pro wheel then Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 30, 2016 Report Share Posted September 30, 2016 My current spare wheel is originally from a sherco, it fits the later gas gas pro if you change the drive side spacer. It also fitted my 2006 scorpa using sherco spacers. I'd be surprised if it didn't fit the later 315 mont and 4rt. From all these possibilities you should be able to get a wheel Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 30, 2016 Report Share Posted September 30, 2016 I considered a Sherco wheel for the 4RT but the distance 'twixt disc and sprocket was 5mm too great. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 30, 2016 Report Share Posted September 30, 2016 You could file 5mm off the spacer if a cheap wheel turned up Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 30, 2016 Report Share Posted September 30, 2016 The spacer wasn't the issue but the width of the hub (ie distance between mounting faces of disc and sprocket). The sprocket would have been 5mm out of line. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) But the sprocket alignment is set by the spacer on that side of the wheel ? once the spindle is tightened up the spacer is setting the distance between the sprocket and the swinging arm. Once the sprocket is set correctly then the spacer on the other side can be adjusted either way. This is just about making a cheap wheel fit the gas gas. Edited October 1, 2016 by baldilocks Quote Link to comment Share on other sites More sharing options...
monty_jon Posted October 1, 2016 Author Report Share Posted October 1, 2016 I don't mind a few mods, as I'm only going to use it for practicing Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) We could have chatted about this tomorrow at Belford Baldilocks but as there is now a trial half an hour away from the house I won't be venturing south after all. Your experience shows that the Sherco wheel can be fitted to several bikes thus answering the OP's question and you suggested, quite reasonably, that it might also fit the Montesa. The only reason I said anything was to avoid any Montesa owners obtaining a Sherco wheel then finding it was not a straightforward fit, not to hijack a thread or start a disagreement. The guy with the Sherco wheel told me that the distance between sprocket and disc on the Sherco was 145mm; I can't confirm that distance. The same measurement on the 4RT is 140mm. The defining factor on wheel spacing is that the caliper, which is on the right hand side of the bike, has to be hard against the swingarm in order to locate on the anchor tab, which also determines where the disc has to be. If I fitted the Sherco wheel then the sprocket would be 5mm too far to the left, which can't be sorted with spacers. The only solution would be, assuming there was enough meat to do so (there definitely won't be on the sprocket side of the hub), to machine 5mm from the face the disc sits on which probably means it won't be a cheap wheel for anyone after all. Who knows why Montesa use a different width of hub from the others but it is a problem for owners who just want a reasonably priced spare wheel. I hope that explains things it not being feasible to put a sketch on here. Edited October 1, 2016 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) We may have to agree to disagree ?. I'll try my friends 4rt wheel in my GG and report back. Thanks anyway as I don't wish anyone to buy a wheel that won't fit their bike. Edited October 1, 2016 by baldilocks Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) Think I've got it now. If we forget about spacers for a moment and measured wheel bearing to wheel bearing that distance may or may not be the same. However what your trying to explain to me is that the relationship between the bearing surface and the sprocket mounting is different. It may also be different on the brake side. So if you solve that with a spacer on one side you are creating a problem on the other side. If it's exactly 2.5mm each side then the swinging arm may be able to flex enough to accommodate it but then that's a whole different set of problems potentially. Thanks for your patience Edited October 1, 2016 by baldilocks Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted October 1, 2016 Report Share Posted October 1, 2016 (edited) That's basically it. I'll just have to keep saving and hope to find a Mont wheel? But if my info on the Sherco dimensions is wrong I'd be delighted. Edited October 1, 2016 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
