valleytrial88 Posted September 29, 2016 Report Share Posted September 29, 2016 i have a gas gas jtx 250 its had new 5w oil and seals in the front forks and had rear shock checked and working perfect but put the heaver black spring on it as red was to weak for me. i am new to trials but would like to set my suspension up i have set the preload om the rear at 12 clicks which is half way and i have set the compression and dampening on the front forks 9 clicks on compression half way and 10 on dampening which is half way i weigh 16.5 stone with all my gear. any advice how to set the suspension up please guys ie sag ect cheers dan Quote Link to comment Share on other sites More sharing options...
