Beta Evo Gear Box Problem
mickmc
I hate to say it but once something goes funny in the box it's in your best interest to open it up. First though pull off the side cover and check the shifter mechanism. You might get lucky and find the problem is there and not in the gearbox proper. At least I hope that's the case.
  • Like 2
I think Beta had an issue with some selector mechanisms around this year.
Some had trouble with a rivet not pressed in properly into the selector arm, which worked loose and popped out.
You might find more info by searching Beta selector fault or rivet.
To get at the selector arm the clutch and clutch basket need to come out, then it should just pull free.
Edited by goudrons
