A Spark, A Spark, My Kingdom For A Spark...
dpyam
My 1978 TY175 was last started several weeks ago and ran like a dream.
Now it won't start - there's no sign of a spark at all.
I'm no electrical expert but so far:
I'm seeing about 3.5 volts AC on the black/white wire to the Low Tension side of the ignition coil.  For this I'm turning the engine over with a drill using the 19mm nut that holds the flywheel/magnets on, with the plug out so that I'm not fighting the compression.
I'm using a digital volt/ohm meter.
So I'm assuming the source coil etc side of things is okay? The ignition "source" ohms are as per the book.
I've tried my spare ignition coil (can't remember where I got it, so it could be duff) and two spark plugs.
Both ignition coils show several thousand ohms on one side but open circuit on the other, which seems a bit odd.
Could both be duff?
I've taken all the connectors apart and reconnnected them, and bypassed the kill switch.
One other thing that may be a clue (or unrelated!!), the last time I tried the headlight it was really dim, even though the bike ran fine.
The electrics appear to be the standard (super-simple) set up so I'm confused I can't work out what's wrong - how hard can it be !!?? :-)
Should be lots more than 3.5v. Hard to say what's faulty. Perhaps the condenser is faulty
HT coil primary 4.5 ohm
HT coil secondary 6000 ohm
Open circuit on primary means its no good.
Edited by andy.t
you should be able to change the condenser on a Ty175 without taking any stator coils off or taking the stator backing plate off the bike
When you spun the motor with the drill and got 3.5V AC, did you have a sparkplug connected between HT and earth, and what RPM did you spin it at?
You used a term for what you did to the killswitch that I thought I had better ask about. Did you bypass it or did you disconnect it?
For what it is worth the most common loss-of-spark issues with TY175s are caused by (in no particular order)
Worn main bearings
Not enough points gap
Dirty or wet or stuck or worn points
Failed condenser
Broken or cracked points or condenser wire
Broken or cracked LT wiring
Sheared flywheel timing positioning key
Failed stator winding insulation (the last few inches) causing a leak to earth
Less common:
Loose stator coil mounting screws
Magnets rubbing on coil laminations
Repaint of frame causing poor earths of motor casings or HT coil
Pinched or rubbed through insulation on killswitch or LT wiring
Faulty HT plug cap
  • Like 3
  • 3 weeks later...
Good news - it's running again :-)
I thought it must be the condenser or ignition coil so changed those but still no joy. Much head scratching.
So I went back to basics, checking everything.
I used my old 1970's Avo meter this time, rather than my digital multimeter (young people may need to google Model 40 Mark 2 Avo meter at this stage!) and everything checked out except the resistance across the points was a bit odd and inconsistent, which wasn't really visible with the digital meter.
So I gave the points a clean and hey presto, ring, ting, ting  :-) :-)
Thanks for all the advice everyone - it made me re-think my strategy - and Feetupfun I will print off your list of common issues and put it inside my Haynes manual for next time.
Edited by dpyam
  • Like 2
