miner Posted October 16, 2016 Report Share Posted October 16, 2016 As above..... been wondering the last twice I've pushed the thing home after it wouldn't hot start! Assume it's the way the clutch is designed to lock up? Maybe to stop it stalling as easy when holding it at low revs/on the brakes whilst balancing? Quote Link to comment Share on other sites More sharing options...
heffergm Posted October 16, 2016 Report Share Posted October 16, 2016 I've never tried, but if I were to, I think I'd put my GG in 5th on a decent hill to have any chance of it working. Quote Link to comment Share on other sites More sharing options...
glynn Posted October 16, 2016 Report Share Posted October 16, 2016 It seems theres 3 ways to start a GG Pro, if it doesnt start within 4 kicks of each of these theres a problem. Either no throttle and kick with choke off, kick with throttle and choke off, or kick with full choke and no throttle. When I first got my Gasser I had a few problems hot starting it, but got the technique now. Bump starting seems to be a bad idea on the Pros, the gearboxes are abit flimsy for that sorta abuse. Quote Link to comment Share on other sites More sharing options...
miner Posted October 16, 2016 Author Report Share Posted October 16, 2016 OuiNon - no/maybe? Pretty desperately tried everything..... seems counter intuitive though, my KTM 525X has a big red anti-choke (hot start) knob to do just the opposite of that..... does it work for GG? heffergm - tried 1-3, thinking maybe higher but would need a big hill and some grip.... no danger of bumping my 300 EXC down a dune with no traction..... thump it and Gas it! Quote Link to comment Share on other sites More sharing options...
glynn Posted October 16, 2016 Report Share Posted October 16, 2016 Gearings so low on the 4 - 2 gearbox on a Gas Gas that it wouldnt be possible to bump it in anything lower than its road gear (5th), I dont even think a Pro 125 would bump in 4th. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 16, 2016 Report Share Posted October 16, 2016 5th / 6th bumps no problem 1 Quote Link to comment Share on other sites More sharing options...
mcman56 Posted October 17, 2016 Report Share Posted October 17, 2016 I have seen someone start a 300 GG pro in 1st gear but it took a lot of technique. A short mild down hill, a big nose wheelie plus a clutch dump while slamming the back tire into the ground. This was on a bet and not his normal start method. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 17, 2016 Report Share Posted October 17, 2016 If it will start with a bump if its not flooded then its technique. The main thing is speed of kick as the faster you kick the better it is, not a heavy kick but a fast one. Generally when hot no throttle or just a little at the end of the kick when the motor is spinning over. Its much easier to show than explain! assumes its a correctly set up carb of course........ Quote Link to comment Share on other sites More sharing options...
