205mi16 Posted October 17, 2016 Report Share Posted October 17, 2016 Hi there, I have recently bought a 199A, and whilst cosmetically it is very good, mechanically it has some issues. This is my first Bultaco, so some help would be much appreciated. There seems to be some funny goings on relating to the wheels. They seem to both be offset in the forks/swingarm. Is this normal or something more sinister afoot? The rear wheel rubs the swing arm unless adjusted out quite drastically. I am wondering if the hubs are from a larger bike etc. I am hopefully attaching some photos that will show the issue I'm having. Your advice is much appreciated, Thanks Quote Link to comment Share on other sites More sharing options...
markg Posted October 17, 2016 Report Share Posted October 17, 2016 Something is for sure wrong. It seems by the photos to have spacers in the right spots. Have the wheels been re-laced with new spokes? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 17, 2016 Report Share Posted October 17, 2016 Sherpa T rims are not meant to be central to the spoke flanges on the hubs, but sometimes are respoked centrally, which puts the tyres off-centre 1 Quote Link to comment Share on other sites More sharing options...
bullylover Posted October 18, 2016 Report Share Posted October 18, 2016 The front ones are always not in the middle of the forks. If you are really concerned just use a long length of string and wrap it around both sides of the rear tyre up on a stand and see how it lines up with the front wheel. I have just respoked a M199 rear wheel and the spokes these days are not long enough on the long side to get the rim far enough over to the brake side. They are all just holding on by a few turns of the nipples. Mine is doing the same as yours now so I have to sort that out. Graham. 1 Quote Link to comment Share on other sites More sharing options...
lbhbul Posted October 19, 2016 Report Share Posted October 19, 2016 (edited) Hi, new friend!! It certainly appears that you have new stainless spokes & wherever it has been re-spoked they have failed to record the original offset & get things true again,the proper distance from the brake brake drum face to the edge of the rim needs to be recorded before the re-spokeing starts to maintain the distance properly. I don't have one torn down or I would be glad to give you the dims. Perhaps someone has wheels down & can measure the offset to help you. If no one can help I will pull my wheels and pass on these dims. Larry Went out and measured front wheel on my m199, 1.150 inch from LH edge of wheel, Rear wheel, 1.600 from RH edge to flat below top edge on each wheel. Hope this helps. Can't get to the brake drum without tearing down sorry. Edited October 19, 2016 by lbhbul 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted October 21, 2016 Report Share Posted October 21, 2016 (edited) the gap between the forks should the same. i have the offset written down some place ill have a look Edited October 21, 2016 by bondy 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted October 23, 2016 Report Share Posted October 23, 2016 199A wheel offset Front brake side 15mm Front None brake side 32mm Rear brake side 40mm Rear None brake side 35mm My wheel builder has been doing my wheels for years never had any problems. Quote Link to comment Share on other sites More sharing options...
205mi16 Posted October 25, 2016 Author Report Share Posted October 25, 2016 Wow, thanks very much for all the replies. We will have a go at tackling this this weekend. Thanks again, Tom Quote Link to comment Share on other sites More sharing options...
205mi16 Posted October 25, 2016 Author Report Share Posted October 25, 2016 We've got the rear wheel on the bench, and have removed the tyre. We have re-spoked the wheel, but it is quite obvious that the spokes for the non-brake side are not long enough to get the offset any where near the values bondy has posted. I have the non-brake side spokes barely threaded, and the offset is roughly: Brake side - 54 Non-brake side - 20 Would anybody be able to advise what to do next? Has anybody been able to source longer spokes? I see that Inmotion just stock for the front wheel of a Bultaco, Thanks, Tom 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted October 25, 2016 Report Share Posted October 25, 2016 (edited) iv'e just looked on that well known web site and they have both front and rear spokes. Just out off interest what size are the spokes both side front and rear. Edited October 25, 2016 by bondy Quote Link to comment Share on other sites More sharing options...
bondy Posted October 26, 2016 Report Share Posted October 26, 2016 (edited) Just Took 2 wheel to my wheel builder today. Edited October 26, 2016 by bondy Quote Link to comment Share on other sites More sharing options...
205mi16 Posted October 27, 2016 Author Report Share Posted October 27, 2016 Just to update this, the longer spokes for the rear wheel on my bike are around 202mm, having spoken to Pete from the well known website, the spokes they sell are 282mm. That should account for the offset I need to put on the wheel! 1 Quote Link to comment Share on other sites More sharing options...
lbhbul Posted October 28, 2016 Report Share Posted October 28, 2016 Tom, wherever you got the spokes new from I pray they have the real deal going on, mine come from this county & really fit , but you friend should be on the proper leg. The dims I gave you early came from my m199 original, if you don't cross the spokes 3 times as orig. then I don't know any other way,I still work in American measuring on wheels that are not bent. Larry 1 Quote Link to comment Share on other sites More sharing options...
lorenzo Posted October 28, 2016 Report Share Posted October 28, 2016 (edited) Tom - I've been waiting for someone/anyone to chime in with all the answers, but it hasn't happened, so here goes......... In response to your original query, it appears from the pics. that these are the correct standard Sherpa hubs and original Akront alloy rims. My 199 parts book lists :- Fr. wheel spokes 18x left hand side 241mm. long 9x right hand side 225mm. long (inners) 9x 227mm. long (outers) 36x nipples (alum. alloy, barrel 6.8mm. dia.) R. wheel spokes 18x right hand side 196mm. long 18x left hand side 176mm. long I've checked some of the genuine Bultaco spokes I have for mod. 159 and mod. 199 wheels and they all conform to these measurements. From the pics. it looks also that the nipples used on your wheels may be undersize - maybe you can confirm the barrel dia. of these ? If you are having a problem with (apparently) short spokes, have you considered that the spokes may be correct, but laced to an incorrect pattern ? How are you measuring your spokes ? Using the above lengths of spokes I don't recall having the problem that you are experiencing but (from memory) none of my wheels are laced like yours; I'm unable to get to any of them at the moment to verify. "Right" and "left" hand above refer to sides of the machine as seen from the rider's view, by the way. Rear rim offset : I've always measured this from the spocket flange on the hub to the outermost edge of the (standard Akront) wheel rim and notes I made for the last three mod. 199 rear wheels I stripped indicate 1 9/16", 1 17/32", and 1 5/8" - take your pick! Front rim offset I can't find at the moment, but would probably be academic, anyway. I usually just centre the rim to the steering axis, as close as poss. Caveat : I'm NOT a wheelbuilder or any sort of expert - someone who is may care to rubbish any or all of the above. Edited October 28, 2016 by lorenzo 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted October 29, 2016 Report Share Posted October 29, 2016 (edited) i should have my wheels back a week on Monday.there at the wheel builders i will put a photo on hear when i get them back thats unless i get a phone call if he has any problems its happened before spokes not being long enough ect. am hoping all is well then i can get on with building my 199B. Edited October 29, 2016 by bondy Quote Link to comment Share on other sites More sharing options...
