netley Posted October 24, 2016 Report Share Posted October 24, 2016 (edited) I have obviously missed something but after re-assembling the clutch I find that the plates are ratting around like a dick up a sleeve. I'll pull it apart again tomorrow though you can see what the problem is here. Also will examine this which seems exactly the same as my 191 though mine has pins, not nuts to hold the springs. If anyone knows the source of my incompetence, I'd appreciate the advice and apologise in advance. Edited October 24, 2016 by netley Quote Link to comment Share on other sites More sharing options...
lanark Posted October 24, 2016 Report Share Posted October 24, 2016 Hi Netley, The key bit in the lower video is at 13:30. The pressure plate only fits in one position where, when fitted over the studs, the cutouts on the inner face fit over the ridges on the clutch hub, as can be seen at 13:30 where the "hand" fits the pressure plate over the studs and keeps rotating it one stud at at time to find the position where the pressure plate slides home fully to clamp up the clutch plates. Hope this helps. 3 Quote Link to comment Share on other sites More sharing options...
netley Posted October 25, 2016 Author Report Share Posted October 25, 2016 Thank you. More grazed knuckles today........... Quote Link to comment Share on other sites More sharing options...
lanark Posted October 25, 2016 Report Share Posted October 25, 2016 I can imaging the fight you must have had to get the retaining pins in with the pressure plate not seated properly!! When seated correctly it's not too bad to get the pins in. 1 Quote Link to comment Share on other sites More sharing options...
netley Posted October 25, 2016 Author Report Share Posted October 25, 2016 Oh I do hope so ! Quote Link to comment Share on other sites More sharing options...
guys Posted October 26, 2016 Report Share Posted October 26, 2016 Get a decent manual, and a lot of these problems won't occur. 1 Quote Link to comment Share on other sites More sharing options...
netley Posted October 26, 2016 Author Report Share Posted October 26, 2016 I never thought it would go on in only one position on first inspection. I have a manual I bought from In Motion though I struggle with following written instruction. You live and learn eh? 2 Quote Link to comment Share on other sites More sharing options...
