Pre-ignition?
paul w
it seems to be an topic with plenty of discussion , so now its my go .
i have an 04 270 rev3 . when the throttle is 3/4 open on climbs or constant going the motor pings .
the bike runs on 98ron fuel , 1.5% oil putoline mx5.
carb is set up as follows
main 150
pilot 30
needle 5c23 on middle position
2.0 slide
a.s. 1 1/2 turns ( i have tried to correct on this but the problem is higher up the fueling than the pilot)
could it be a squish clearance too tight?
it feels like its too lean on the needle
any advice ,or how you cured yours would be appreciated.
there are ignition timing diagrams on JLI's website.
www.thetrialcompany.com
If you have a bike which is <03 model or which is a 200 then it will have a different stator so don't set your ignition timing up like this! :D
Bob
  paul w said:
do all 270's suffer like this?
I've heard of a few with the same problem. I'd also check your ignition timing as descibed elsewhere in this thread but I did that first on my bike and it was spot-on. No idea why the pilot jet would have any effect on a problem that only manifests itself when you're hard(ish) on the throttle but I'm sure someone more mechanically knowlegable than me will be able to explain that :D
Edited by neonsurge
