4Rt Rear Shock
taff_d
I have a 2015 Repsol 4rt with the std Showa suspension which I have no issues with, BUT I have a Ohlins rear shock sat in my garage doing nowt that I had on my Beta Factory. My question is, is the Ohlins shock better than the std Showa is it worth getting the Ohlins sorted to fit the Mont ???
The standard Showa is a great shock, however stock configuration doesn't work as well as a properly setup aftermarket Ohlins if you haven't had the Showa setup for your weight.
And service of the Ohlins is often less expensive and easier to find a local shop.
Edited by jonnyc21
