Electrex Ignition
scbond2
Mine was a direct fit. Just follow the instructions. Even the ignition timing was fairly correct when I mounted it according to the instructions, only a minor adjustment was needed because I'm a perfectionist.
The flywheel came with a suitable puller included.
And the lighter flywheel is an advantage in my books; it makes the engine more responsive.
  On 11/19/2016 at 4:39 PM, carl ekblom said:
You may move the ignition plate in slotted holes, but for precise adjustments I guess you need a strobe light. Mine is set accordingly to their spec and my bike runs well. See https://www.dropbox.com/s/zcfoxs3bbdzit58/STK-154.pdf?dl=0
So do you know what the btdc is?
I have not checked it with a strobe but it should be close to 10 degrees at idle (Electrecx World spec) . I don´t know the C-C length of the conrod but if I asssume it is 1.8 times the stroke (60mm) that would be 0,6mm btdc increasing to 23 degrees (3.0mm btdc) at full advance.
  • 3 weeks later...
