Drum Brake Strip Down...some Tips For Those Like Me.
iconic558
Noticed the brake lever arm being a little reluctant coming off when I was practicing on Sunday....did the usual 'remove the dipstick from the van and dribble a tad of oil around the arm desperatation trick'....its bad maintainance on my part, no excuse. The more keen eyed would have noticed two dipsticks in my van on Sunday, myself being the other.
The old girl since being rebuilt 2 years ago (?), has only had the carb cleaned once and the gearbox oil dropped 5 or 6 times, in that time she has lead an 'on and off' life as my enthusiasm has gone from peaks to troughs...I'd rather lay on a Norfolk beach than do a trial in the summer and watch my 5 year enjoying herself...maybe I should drag Speedy down to Mundesley next time...anyhow...
I thought I'd strip and clean the brakes out but got beaten by bad light. I then come across an article about setting up brakes and thought, I wonder how much of this is new to those whom weren't brought up on drums?
Reading it I knew never to mix the shoes up once 'bedded in' but didn't think about marking the camshaft before removal, these old cams are all old and must have taken a 'set' by now.
The bit about centering the brake plate using the brakes themselves works well from experience and I even made my axle hole larger when I rebuilt her which improved things too.
anyhow most will know all this, but for some it may be useful.
The guy is writing about cycle drums but it all transposes over very well.
http://bikesmithdesign.com/tips/drum-brakes.html
Edited by iconic558
  • Like 3
I must be blessed !!!  none of the numerous Fantic/ grimeca drums I have , have any bad actual drum wear .but it still takes some time to set them up for stoppies etc ....
even with the 300 backing plate . on one of my rears i have added a shim around the anchor pivot though , and it does help alot  ..( beer can and tin snips ...:0 )
Edited by axulsuv
  • Like 2
I'm amazed my brakes worked as well as they did....they were full of muddy crap and was muxed in with oily crap in the rears. The shoe grooves were full!
Brakes all cleaned and greased up and working excellently.
How often are you guys stripping n cleaning out brakes...I would guess once every two years isn't often enough!
Edited by iconic558
Wet trial = heat up brakes after trial before loading bike into transporter to get drum surfaces as dry as possible. When I get home, clean external mud off bike then take wheels out and dry brake parts fully.
Then some time before the next ride, service the brakes
Lordy.....my maintenance regime is seriously lacking
You might look up how well the drum brake shaft fits to the bore inside the drum brake plate. The shaft should sit "flush" without any gap. If this assembly is loose fit it the performance of the brake won't be so good as part of the force you engage will be lost through this nonalignment. If the shaft bore has been widened a bit you might install a brass bearing. The shaft and bore should be greased periodically with waterproof grease not cupper grease which attracts dirt too well. Cupper grease can be applied in slight amounts between the upper and lower brake shaft and the brake shoes.
Another tipp, keep the inside of the brake clean and wipe out any brake out dust either from the brake hub or the brake plate assembly. This will provide better performance even if there has got water inside, as the dust and the water mixture is a slippery grease.
I do look up the springs of the brakes too as these might be bend or been partly exchanged. They should both be similar in strength and length.
Last by not least I clean the brake pad with a wire brush from all debris and look up if the shorter edges of the pads are still non rectangles.
I now all of the "tipps" above have only little effect but if you have done them all there should be a noticeable improvement in performance and they do also brake good once got wet.
  • Like 2
Mmmh these small parts are not easy to find beside used at Fleabay:
here: http://www.bdi-production.com/en/92-partie-cycle
here: http://bmz-equipements.fr/partie-cycle/1211-came-de-frein-grimeca.html
here: https://www.ost-moped.de/grimeca.html
But I would ask in forehand if the dimensions are really what you need!
Many thanks
