surface Posted November 13, 2005 Report Share Posted November 13, 2005 Hi, I'm new on here, and have little bike knowledge, wondered if one of you more experienced guys could help me out. I have a 02 Sherco 250, it runs great but I have one problem with it. It starts first kick but when cold if I select a gear it jumps forward and stalls. To get round this i have to perform a rolling start, before selecting the gear. Once its warmed up I have no further problems. Have you guys any idea what causes this and if so what do i need to replace or fix? Any advice would be much appreciated. Cneers Quote Link to comment Share on other sites More sharing options...
john.b Posted November 13, 2005 Report Share Posted November 13, 2005 They all seem to do it.I have two techniques for this. Firstly at home where I don't want to disturb the neighbours, before I start mine I put it in top gear then pull in the clutch lever and rock the bike backwards and forwards slightly. You will initially feel some resistance but after a few seconds you hear and feel the clutch free itself. The bike then rolls backwards and forwards freely. Then I put the bike back in to neutral and start her up. When you put the bike in gear it should normally stay still. At a trial on the other hand I usually start the bike and leave it ticking over for a couple of minutes to warm the oil normally does the trick. Changing the transmission oil at very frequent intervals also makes a massive difference to not only your engine life but also trying to selecting gears and neutral. Quote Link to comment Share on other sites More sharing options...
bikespace Posted November 13, 2005 Report Share Posted November 13, 2005 Yep - Most seem to do it. I normally knock it in to gear and put both brakes half on for a bit. Soon clears, and with the sudden stop you can performa neat forward roll over the bars. Gets you used to falling off for the day. Not something that is worth trying to fix. Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted November 13, 2005 Report Share Posted November 13, 2005 Try using 5w30 oil - thats how we solved the problem with all the bikes -(Canada) - (change it often & switch to 10w40 for the summer - make sure you use motorcycle oil as many automotive oils can cause clutch slip Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 13, 2005 Report Share Posted November 13, 2005 Use tqf its better for the uk. They all do it just remember to strt where there is space! Quote Link to comment Share on other sites More sharing options...
martc Posted November 13, 2005 Report Share Posted November 13, 2005 i bought a brand new 290 the other week that has done it twice , my mate bought a brand new one the other day, that has done it already aswell, and my other mate has an 03 he said his does it mart Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 13, 2005 Report Share Posted November 13, 2005 Its directly related to the time it sits still. Quote Link to comment Share on other sites More sharing options...
shercoholic Posted November 14, 2005 Report Share Posted November 14, 2005 When you load up the trailer/van/transporter, tie a strap/bungee cord around the clutch lever and handlebar. After starting the engine from cold hold the clutch lever in against the bars with your right hand, while waiting for the engine to warm up, ...and while you search for the choke lever with your left hand. Once warmed up remember to switch hands! As Dabster points time sitting still is a factor. While the bike was parked all week doing nothing in the cold garden shed, the clutch spring pressure was squeezing the oil out from between the cork and metal plates - just let things warm up a little before tearing off across the carpark. Gentle brake pressure perhaps but none of this 'jamming on the brakes/over the bars routine' if the family jewels are at all important! Quote Link to comment Share on other sites More sharing options...
