Ty175 Oversize Piston + 2Mm
mattylad
I am looking for a 2mm oversize piston for a Ty175.
I assume it will have to be aftermarket, does anyone know of a brand that lasts as it will be on its last bore and the porting is good.
The new 1.5mm that was in when I bought the cylinder has lasted about 2 trials before starting to rattle hence the question and I cannot identify the brand
That’s probably more to do with who bored it rather than the piston
I never come across a piston that wears out after two trials no matter how cheap!
hello, 2mm oversize that would be 68mm ?
I have seen these on ebay for the DT175 , which should be interchangeable with a TY175
 {but check before buying, I could be wrong}
also seem to remember the TY250 mono, standard size piston was 68mm, I think and MAY fit
again check all dimensions before buying , its been a few years since I had the same problem and I cant remember which piston I ended up using !
hope this is helpful
It's key to get the re-borer to bore to the piston type being used - cast metal piston or whatever type, as different rates of piston heat expansion for the new piston being used have to be taken into account by the re-borer, with regards to +/- a thou or two of the re-bore.
Edited by dpyam
