fantic tom Posted November 20, 2016 Report Share Posted November 20, 2016 I'm having some bother with my fantic 305, it will only run with the choke on. With choke off it runs up and down and and soot up the spark plug. Iv stripped and cleaned the carb and took off the reed valve and checked them and all looks good! The manifold lookx good too no ctacks ect. Any ideas what else I could check? Cheers! Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 20, 2016 Report Share Posted November 20, 2016 You need to clean the choke circuit including the float bowl. Quote Link to comment Share on other sites More sharing options...
fantic tom Posted November 20, 2016 Author Report Share Posted November 20, 2016 Thanks for that, does it all seperate easily? Quote Link to comment Share on other sites More sharing options...
zisko62 Posted November 20, 2016 Report Share Posted November 20, 2016 I'm having some bother with my fantic 305, it will only run with the choke on. With choke off it runs up and down and and soot up the spark plug. Iv stripped and cleaned the carb and took off the reed valve and checked them and all looks good! The manifold lookx good too no ctacks ect. Any ideas what else I could check? Cheers! are you sure the pilot jet is ok? if there is the genuine dellorto carb fitted, it'd have a 2nd slow jet and circuit in the bowl. is this circuit ok? Quote Link to comment Share on other sites More sharing options...
fantic tom Posted November 21, 2016 Author Report Share Posted November 21, 2016 All looks clean I stripped i took them all out and blew them out with carb cleaner. It is a genuine dellorto carb. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 21, 2016 Report Share Posted November 21, 2016 Does the 305 fantic carb have an air screw or a petrol screw ? Quote Link to comment Share on other sites More sharing options...
zisko62 Posted November 22, 2016 Report Share Posted November 22, 2016 it'd be a air screw this type of dellorto (oval inlet) is very difficult to set up. It has a really small pilot jet and this is hidden really deep in the body so most time it is blocked Quote Link to comment Share on other sites More sharing options...
fantic tom Posted January 2, 2017 Author Report Share Posted January 2, 2017 Sorted! I changed an o ring on one of the jets and a bit of an adjustment on the air screw and it now runs brilliant! 1 Quote Link to comment Share on other sites More sharing options...
