bfgjohno Posted November 24, 2016 Report Share Posted November 24, 2016 Hi Very new to this game and I'd be very grateful for any help! I've a 2010 beta evo 250 2T and haven't ridden it much this year. I now find that it starts and runs perfectly but when I engage gear - weh hey I'm doing a wheelie as the clutch doesn't seem to be effective. Little bit scary! Sticking it up on a stand the rear wheel is being driven in all gears even if the clutch is pulled in. When I do pull the clutch in there's a clicking noise from the engine which increases in frequency with revs applied. I ran it for a bit but nothing changed. Any clever diagnosticians out there that could point me in the right direction.........? Thanks in anticipation! All the best John Quote Link to comment Share on other sites More sharing options...
bfgjohno Posted November 24, 2016 Author Report Share Posted November 24, 2016 click on this to see how your clutch works. Oni nou - thankyou so much for this! Brilliant video and great explanation. I'll give it a go tomorrow. :-) Quote Link to comment Share on other sites More sharing options...
jonnyjibs Posted November 24, 2016 Report Share Posted November 24, 2016 With the engine off, click it up into a high gear, pull the clutch in then gently rock back and forth till the plates free themselves. Once free find neutral again, start the bike engage the clutch and click it into gear. Be prepared for the clutch to drag till it warms up though, so make sure you have a nice clear run till it does! Quote Link to comment Share on other sites More sharing options...
fxstbi Posted November 24, 2016 Report Share Posted November 24, 2016 jonnyjibs is exactly right. My Sherco clutch sticks after setting for several days. I pull it into third gear and do the same as jonny, rock it a few times with the clutch pulled in and it breaks free easily. Start up and go, I don't have any drag, my clutch works normal immediately. Quote Link to comment Share on other sites More sharing options...
billyt Posted November 25, 2016 Report Share Posted November 25, 2016 (edited) It is NOT a good idea to leave your bike for a long period of time with the clutch or brake pulled in by string, elastic or whatever. This will cause premature seal leakage as the hydraulic fluid will be under pressure for a long time and will eventual cause the seals to weaken or fail. Besides there is NO need for that at all if you do what was suggested by rocking etc. Edited November 25, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
dan williams Posted November 25, 2016 Report Share Posted November 25, 2016 See clutch fix pinned at top of forum. Quote Link to comment Share on other sites More sharing options...
totty79 Posted November 25, 2016 Report Share Posted November 25, 2016 +1 on Rocking for initial release, and stripping the clutch stack if this doesn't work. Clutch fix instructions for a general improvement, with new plates and steels as an option if the fix don't work. Oil choice also has an effect but I'd rather not start another oil debate. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted November 25, 2016 Report Share Posted November 25, 2016 Rather than placing up against a wall and coarsely banging it in to gear try holding the clutch in and pushing the bike off slightly with your foot as you engage bottom, then, with the lever still held in, work your way up the gearbox. It should free off when you reach fourth. Quote Link to comment Share on other sites More sharing options...
billyt Posted November 25, 2016 Report Share Posted November 25, 2016 (edited) Oni Nou I have never had this happen to me as I would never do it. How ever I do know of some guys where it did happen to. The key here is the original post and I quote "and haven't ridden it much this year." which says to me it was sitting for long period of time. What you are proposing is the same as tying down your forks and loading the front fork seals under pressure and leaving it that way for a while, never a good idea. Keep in mind some guys store their bikes for the winter months so I am just asking the guys to be cautious of doing this for an extended period of time. Also is the possibility that the oil soaked fibre plates can swell if the pressure is removed from them for an extended period of time. This is know from fact and first hand experience. Respectfully BillyT Edited November 25, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
dan williams Posted November 25, 2016 Report Share Posted November 25, 2016 In Billy I trust. He's helped me understand an awful lot of the stuff I've later tried to expand upon. I still say if I could get within spitting distance of what he and Jon know I'd be a bright boy indeed. Quote Link to comment Share on other sites More sharing options...
bfgjohno Posted November 25, 2016 Author Report Share Posted November 25, 2016 (edited) Your clutch plates are stuck together because they have not been seperated for a while by using the bike. To clear the problem find a strong wall to put the front wheel against and hold the front brake on firmly then with the clutch lever held pulled against the grip try kicking the bike over.if it will not start then you will need to find neutral first then when the engine is running click it into gear with some revs on and it should free the clutch plates. Another way will be to take the clutch pates out of the basket and separate them that way before oiling them and putting everything back together again. You can avoid this problem by pulling the clutch lever to the grip and putting a strong cable tie or strap around it to hold it in that position while it is not being used; and so stopping the clutch plates being pressed together for long periods. Worked a treat thank you +++. Still a lot of dragging though. I think I'll change the gearbox oil tomorrow - and maybe then the clutch fluid. Then - if all else fails, open the girl and fettle those plates.......... I know it's been covered to the nth degree before ;-) but .......... ATF, 20w40 gear oil or a dose of the Motorex Cross Power 4T 10w50 I've got lying around for my KTM690 or another (that I can buy in N Yorks)............? Edited November 25, 2016 by bfgjohno Quote Link to comment Share on other sites More sharing options...
guy53 Posted November 26, 2016 Report Share Posted November 26, 2016 I live in Quebec, so the bike sit still for 4 month in the shed, from what I understand I should pull the clutch lever and ty it in that position for the winter ? Guy Quote Link to comment Share on other sites More sharing options...
billyt Posted November 26, 2016 Report Share Posted November 26, 2016 (edited) Mon bon ami dieu pas. Lisez attentivement ce qui a été écrit. Friends don't let friends strap clutch levers down for the winter. Edited November 26, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
guy53 Posted November 26, 2016 Report Share Posted November 26, 2016 Merci billyt je vais suivre votre conseil, Thank's billyt I will follow your advise, and I plan to do the clutch mod ( clutch fix ) Guy Quote Link to comment Share on other sites More sharing options...
