james111089 Posted November 13, 2005 Report Share Posted November 13, 2005 hi, my 2002 beta rev 3 has the 2 wheel pacers and a washer came off aswell is this spose to be there or has someone put it there any why? Many thanks James Quote Link to comment Share on other sites More sharing options...
beebee Posted November 14, 2005 Report Share Posted November 14, 2005 The washers are wheel bearing protectors. Quote Link to comment Share on other sites More sharing options...
james111089 Posted November 14, 2005 Author Report Share Posted November 14, 2005 there was only one and it was the same diameter as the spacers and it doesnt sit near the bearings Quote Link to comment Share on other sites More sharing options...
beebee Posted December 3, 2005 Report Share Posted December 3, 2005 (edited) Ahh, that is a spacer for the wheel spindle. If you put the wheel in the bike and sat the caliper on the disc you will notice there is a gap on one side of the wheel spacers this is where the washer goes. {I think it is the R/H side if you were sat on the bike?} It is there so when you tighten the wheel spindle it keeps the forks at the correct distance apart. Edited December 3, 2005 by BeeBee Quote Link to comment Share on other sites More sharing options...
james111089 Posted December 3, 2005 Author Report Share Posted December 3, 2005 Ahh, that is a spacer for the wheel spindle. If you put the wheel in the bike and sat the caliper on the disc you will notice there is a gap on one side of the wheel spacers this is where the washer goes. {I think it is the R/H side if you were sat on the bike?}It is there so when you tighten the wheel spindle it keeps the forks at the correct distance apart. thats what the spacers do why not just have a slightly larger spacer then James Quote Link to comment Share on other sites More sharing options...
bob Posted December 3, 2005 Report Share Posted December 3, 2005 surely putting spacer on that side makes no difference since the spindle just screws in until it meets the 'top hat' things which go into the bearings????? Bob Quote Link to comment Share on other sites More sharing options...
