walshy_7 Posted December 5, 2016 Report Share Posted December 5, 2016 Hi all I have a 2007 sherco 250 and was out riding the other day the bike started heavily smoking and breathing oil from the crank case I'm putting it down to crank Seal on the clutch side? Question being is it a bad job is the seal on the outer side of the engine casing or is it full strip down ? Any help would be greatly appreciated Thanks Chris Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 5, 2016 Report Share Posted December 5, 2016 Can be replaced with the engine in the frame still. The clutch needs to come off to do it & a new clutch cover gasket is the only extra part that you really need although I would suggest replacing the water pump seals while the clutch cover is off Quote Link to comment Share on other sites More sharing options...
walshy_7 Posted December 5, 2016 Author Report Share Posted December 5, 2016 That's great much appreciated matey thanks Quote Link to comment Share on other sites More sharing options...
