lopez Posted December 23, 2016 Report Share Posted December 23, 2016 Recently picked up a Rev 3, clutch master was leaking so rebuilt that and reverse bled with a syringe. Clutch does stick a bit when cold, rocking it back and forth frees it off. If I start the bike in first with the clutch in, it starts fine and I can then ride away normally If I start the bike in neutral and then put it into first, it stalls before I've had a chance to release the clutch - as if I haven't actually got the clutch pulled in at all. Riding normally I can change gear fine, and if I pull the clutch in and leave the bike in gear it doesn't stall when I come to a stop. Any ideas? Quote Link to comment Share on other sites More sharing options...
wheelieman14 Posted December 23, 2016 Report Share Posted December 23, 2016 There is a fix pinned to top of Beta forum that explains how to clean (file out) glue between raised surfaces of friction plates; allowing better access to oil flow between clutch plates and helps resolve the problem you are describing. Here is link: http://www.trialscentral.com/forums/topic/28407-the-beta-clutch-fix/ 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 23, 2016 Report Share Posted December 23, 2016 Beta and many bikes do this when cold. Not a big deal, but always point the bike in a clear direction. Quote Link to comment Share on other sites More sharing options...
lopez Posted December 24, 2016 Author Report Share Posted December 24, 2016 I took it for it's first proper test ride since I've had it today. Once it was nicely warm it's fine, doesn't grab at all, so I think I can live with it for now. Quote Link to comment Share on other sites More sharing options...
