master68 Posted December 24, 2016 Report Share Posted December 24, 2016 I want to refresh my Sherco specifically regrease wheel bearings, steering head bearings, and swing arm bearings. Are there Any guides, manuals, YouTube vids on the topic? I want to do myself but I have limited mechanical ability. You thoughts would be appreciated. Quote Link to comment Share on other sites More sharing options...
collyolly Posted December 24, 2016 Report Share Posted December 24, 2016 (edited) It is all quite straightforward for a mechanical mind, if as you say you have limited experiance can you give an example of what you do have experiance of ? I cannot be specific about a Sherco as I have a Gasser but removing the swingarm to clean and grease the linkage is not a job for someone with limited experiance or as is probably the case a limited toolset. Also head bearings are not easy to get to then you have to reset the 'clearance' . Have you got a club member or riding mate that has done their own maintainance that could lend a guiding hand ? Take plenty of photos as you go and take your time until you are familiar with all the parts Good luck Edited December 24, 2016 by collyolly Quote Link to comment Share on other sites More sharing options...
cascao Posted December 24, 2016 Report Share Posted December 24, 2016 It's not hard work. Take photos when disassembly it can be useful on reassembly Lewisport usa have a good bit old manual that can help a lot http://www.lewisportusa.com/manuals/sherc_11-21-09/sherco_setup_and_lubrication_guide.pdf And is good having dogbone bushings before starting service. It's cheap and service will be perfect if you replace them. (16.18 and 16.19 on pag 19) Quote Link to comment Share on other sites More sharing options...
master68 Posted December 27, 2016 Author Report Share Posted December 27, 2016 Thank you for your input. Quote Link to comment Share on other sites More sharing options...
