Ti Dog Bones - Grease Path?
mcman56
I see there are ti dog bones with grease fittings.  How does the grease get to the bearings?  Are the bolts drilled through for a grease path?  Are they a larger bolt diameter than oem?  Are the inner races cross drilled?  Are the bearings the same size as oem?  Or...how do they work?
