craigack Posted December 27, 2016 Report Share Posted December 27, 2016 Hi guys merry Christmas! I''m going to view a Sherco 2013 290 later on this afternoon any pointers? Any common issues I should look for? Thank you in advance. Craig. Quote Link to comment Share on other sites More sharing options...
bishyfishy Posted December 27, 2016 Report Share Posted December 27, 2016 How easy is it to start? approximate order of expense will be: Any piston/bore rattles Crank/main bearing noise gear selection issues Shock linkage play/movement Wheel bearing play Steering bearing play brakes& clutch hydraulics leaking fork seals easy stuff to change are chain sprockets and tyres but still costly. Plenty of info under the Sherco forum on this excellent site! Quote Link to comment Share on other sites More sharing options...
