2013 Sherco 290
craigack
How easy is it to start?
approximate order of expense will be:
Any piston/bore rattles
Crank/main bearing noise
gear selection issues
Shock linkage play/movement
Wheel bearing play
Steering bearing play
brakes& clutch hydraulics
leaking fork seals
easy stuff to change are chain sprockets and tyres but still costly.
Plenty of info under the Sherco forum on this excellent site!
