betasweden Posted December 28, 2016 Report Share Posted December 28, 2016 Hi guys! I have just received my new Beta 300 4T -17. I have always been riding 2T before. But I don’t seems to get it to work properly. It seems like it don’t get enough gas when i have full gas. You can really feel it when you driving on the road on maybe 5th gear and quickly turn on full gas. Or standing still and turn on full gas to jump up a large rock or something. I have seen some older topics regarding the carb set up. “Set the nail to the bottom slot” “turn the mixture screw” etc. But does anyone have any experience regarding the 2017 or maybe 2016 Beta 4T? Or is this problem for every Beta 4T? Your help would be highly appreciated! Br/ Daniel Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 28, 2016 Report Share Posted December 28, 2016 (edited) I did know someone many years ago with a Beta fourstroke who was not aware that it had a well hidden button, I think to assist with hot starts (whatever it was it was not the choke). It ran properly once that was in the correct position. Edited December 28, 2016 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
madmostin Posted December 28, 2016 Report Share Posted December 28, 2016 5th gear and turn the gas. They have a cv carb. Works very well. The hot start lever if not home properly will make the bike run unevenly. Likewise if the choke is not fully down will make it run awful. Run the machine in then look to getting the bosi tailpipe. Improves the power. Quote Link to comment Share on other sites More sharing options...
betasweden Posted December 28, 2016 Author Report Share Posted December 28, 2016 Thanks guys!But i think is has nothing to do with the "hotstart" or choke. Regarding Bosi i have ordered Quote Link to comment Share on other sites More sharing options...
fxstbi Posted December 28, 2016 Report Share Posted December 28, 2016 Hi guys! I have just received my new Beta 300 4T -17. I have always been riding 2T before. But I don’t seems to get it to work properly. It seems like it don’t get enough gas when i have full gas. You can really feel it when you driving on the road on maybe 5th gear and quickly turn on full gas. Or standing still and turn on full gas to jump up a large rock or something. I have seen some older topics regarding the carb set up. “Set the nail to the bottom slot” “turn the mixture screw” etc. But does anyone have any experience regarding the 2017 or maybe 2016 Beta 4T? Or is this problem for every Beta 4T? Your help would be highly appreciated! Br/ Daniel They come from the factory set lean. I just got a new 300 4t Factory and I put a 130 main and a 27.5 pilot jet in it and it runs great. I left the needle clip in the stock position. I put a remote mixture screw on when I did the jets and it's about 1.5 turns out. 93 octane pump gas runs fine. I live in Texas and we're at about 500' above sea level and the temps now are about 70 degrees f. Hope this helps. Quote Link to comment Share on other sites More sharing options...
betasweden Posted December 28, 2016 Author Report Share Posted December 28, 2016 Hello, Thanks i will try this! So you did nothing with the needle? Quote Link to comment Share on other sites More sharing options...
motomofo1 Posted December 28, 2016 Report Share Posted December 28, 2016 What elevation are you at? Quote Link to comment Share on other sites More sharing options...
carlos Posted December 28, 2016 Report Share Posted December 28, 2016 My 2016 300 factory almost killed me! It would run out of fuel while going up a steep incline with the throttle wide open. It came with a 120 main, on the middle neddle clip. Put in a 122.9 main jet with clip at bottom and it worked better, still would hesitate on w.f.o. Installed a 125.0 and it was pretty good. Now running a 127.5 main jet, with clip in middle position. Works great. Had trouble on hot starts. Started using the hot start button and now it starts great, hot or cold. I am running at a little above sea level - 500 meters. Quote Link to comment Share on other sites More sharing options...
betasweden Posted December 28, 2016 Author Report Share Posted December 28, 2016 Sea level is about 150meters. I will try with a 130jet and a 27,5. Hope it will work. Quote Link to comment Share on other sites More sharing options...
fxstbi Posted December 28, 2016 Report Share Posted December 28, 2016 Hello, Thanks i will try this! So you did nothing with the needle? I left the clip in the third groove from the top. That is how it came stock. I have no hesitation or lean indications. It runs great at any throttle position. I just checked and my mixture screw is 2 turns out. Quote Link to comment Share on other sites More sharing options...
betasweden Posted December 29, 2016 Author Report Share Posted December 29, 2016 I left the clip in the third groove from the top. That is how it came stock. I have no hesitation or lean indications. It runs great at any throttle position. I just checked and my mixture screw is 2 turns out. I have ordered an 130 Main and a 27,5 jet. Really hope i will have them before the weekend. Will let you know how it runs after. Thanks, for your help!! Quote Link to comment Share on other sites More sharing options...
retromlc Posted December 31, 2016 Report Share Posted December 31, 2016 i have a 250 4/,does a pipe improve power? if so which one Quote Link to comment Share on other sites More sharing options...
betasweden Posted January 2, 2017 Author Report Share Posted January 2, 2017 Hello, I changed to the 130 Main this weekend and work much better now! Thanks! The 27,5 jet was already fitted from factory. So only one needed to be changed. (Nothing with the needle) I have not fitted the Bosi Arrow exhausted yet. But people say it should be better and also better sound. Quote Link to comment Share on other sites More sharing options...
betasweden Posted January 2, 2017 Author Report Share Posted January 2, 2017 On 2016-12-31 at 6:55 PM, retromlc said: i have a 250 4/,does a pipe improve power? if so which one Hello, I have not fitted the Bosi Arrow exhausted yet. But people say it should be better and also better sound. 1 Quote Link to comment Share on other sites More sharing options...
