jonny 1234 Posted December 31, 2016 Report Share Posted December 31, 2016 hi iv got a rev3 and the clutch isn't working theres fluid in the cylinder and nothing leaking. any ideas ? just can't select any gears . Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 31, 2016 Report Share Posted December 31, 2016 So you are riding it and cannot shift? Or is the clutch just not working? The plates stick on a Beta. Either ride it around with the clutch in and use the brakes till it releases. Or just rock it back and forth with it in gear before you start it. Always point the bike in a clear direction. Quote Link to comment Share on other sites More sharing options...
jonny 1234 Posted December 31, 2016 Author Report Share Posted December 31, 2016 thanks . its like when you pull the clutch theres noting there. iv only had a bike a few weeks so I'm new to all this ..thanks neutral was hard to find when i was last out as well Quote Link to comment Share on other sites More sharing options...
guy53 Posted January 1, 2017 Report Share Posted January 1, 2017 Oil in the can does not mean leverage on the clutch release. Try bleeding the system ( good time to change the oil Guy Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 8, 2017 Report Share Posted January 8, 2017 Hi Jonny, when you pull in the lever does it have any resistance and return after you release it or does it just pull in and stay? Beta's have a notorious clutch stick when cold that can be fixed by cleaning up the fiber plates. The fix is pinned at the top of this forum. Quote Link to comment Share on other sites More sharing options...
