barfy Posted January 7, 2017 Report Share Posted January 7, 2017 Stripped down the 4RT for a new cam chain etc. and had some starting problems which I thought I'd solved but after a couple of weeks it won't start again. I think I've got the tick over screw in the wrong place because it almost wants to start but won't quite. There is a big blue spark on the plug. Where about should the tick over screw be set? On a carb they say "1 to 1 1/2 turns out" but what about the 4RT EFI. Quote Link to comment Share on other sites More sharing options...
ourian Posted January 7, 2017 Report Share Posted January 7, 2017 First try winding it in or out half a turn from it's current position, if still no go then, try winding the screw right out until it runs out of threads, then wind it back in 10 turns and experiment from this position. 1 Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted January 7, 2017 Report Share Posted January 7, 2017 (edited) Turn it in (CW) to closed, then open it 3 full turns (CCW). This should get you to a point where it'll start, but it may be a little high on the rpm, so you may have to close a little from there. Edited January 7, 2017 by sportsawyer 1 Quote Link to comment Share on other sites More sharing options...
barfy Posted January 8, 2017 Author Report Share Posted January 8, 2017 Thanks guys. I'll give your suggestions a try later in the week. Quote Link to comment Share on other sites More sharing options...
barfy Posted January 12, 2017 Author Report Share Posted January 12, 2017 Whoop whoop. It worked and now I can start the Mont no problem. thank you guys. Most helpful. 1 Quote Link to comment Share on other sites More sharing options...
barfy Posted March 17, 2024 Author Report Share Posted March 17, 2024 Changed the throttle body on my 2015 Repsol and it wouldn’t start. Came back to this thread to reset the tickover screw. Whoop, whoop. 1 Quote Link to comment Share on other sites More sharing options...
