fantic tom Posted January 8, 2017 Report Share Posted January 8, 2017 (edited) Iv got a really tidy (looks unfitted) swing arm for my 305. When fitting tonight I have a problem - the buses are looser on the new swing arm..... Is there a removable press fitted part in there ? Or is it just a different size swing arm hole? Cheers! Tom. Edited January 8, 2017 by fantic tom Quote Link to comment Share on other sites More sharing options...
axulsuv Posted January 10, 2017 Report Share Posted January 10, 2017 The Bush should be tight to the swingarm and rotate on the shaft , you've got some knackerd bushings .... Measure id , od. etc and get some needle brgs to replace the bush , Maybe ? Quote Link to comment Share on other sites More sharing options...
fantic tom Posted January 10, 2017 Author Report Share Posted January 10, 2017 Sorted. There was a seaky sleeve in the old swing arm it took a long reach socket and a vice to drive it out. Now pushed into the new swing arm and all snug again. 1 Quote Link to comment Share on other sites More sharing options...
