scorpion Posted January 18, 2004 Report Share Posted January 18, 2004 i want to put a kill switch on instead of the light cluster , anyone changed theres and what wires are what ? cheers mick Quote Link to comment Share on other sites More sharing options...
kinell Posted January 18, 2004 Report Share Posted January 18, 2004 I bought a 2-wire kill switch. Wire it up to the 'grey' and the 'green/black' wires in the multi-plug. I think I also connected one of the wires to the frame for a good earth. Quote Link to comment Share on other sites More sharing options...
ron Posted January 19, 2004 Report Share Posted January 19, 2004 No bike is easier to change to a kill switch than the beta.. If you want to remove all of the lighting wiring (this is the easiest and lightest way) just remove all wires through access hole in top of frame pull slightly and all should come out leaving you with 2 yellow wires( a male and female connector) plug them together... you will have only one wire left which is a black w/white stripe this is your kill switch wire.. hook it to a single wire kill switch and you are finished... If you want to use a two wire kill switch hook one wire to the black w/ white and one to the frame or triple clamp no problem ... 10 minute job ... Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted January 19, 2004 Report Share Posted January 19, 2004 That's really nice! Good to see when a manufacturer takes something like that into account and makes it simple. Go for the 2-wire button. Don't depend on the button body-to- handlebar-to-clamp-to-top tree-to-stem-to-neck bearing-to frame connection for your ground. Go right to the frame. Quote Link to comment Share on other sites More sharing options...
scorpion Posted January 19, 2004 Author Report Share Posted January 19, 2004 cheers guys, as helpful as ever regards mick. winning lottery numbers anyone ? Quote Link to comment Share on other sites More sharing options...
