map and light buttons to be moved
mikerenief
Hi
On mine I've just removed the light switch further back from the headstock at the connector. For the mapping switch I made a loop to shorten the cable then zip tied this to the clutch hose where it enters the frame behind the headstock. Map 1 doesn't seem short of power
  On 2/1/2017 at 12:08 PM, baldilocks said:
Hi
Expand
As an aside, I hadn't realised you'd gone TRS. Which one do you have? Any general comments on how it compares?
Edited by cleanorbust
Hi Cleanorbust
Nothing wrong with the gas gas, Ive had 8 over the years but I just wanted a change.
I've got a 280 RR and I'm very impressed with it. Admittedly I've only ridden it twice. Feels lighter than a gg to ride front end is more stable. Suspension  / power awesome . At the moment all I've done is wound some off the rear spring and turned the mixture screw in about half a turn.
Edited by baldilocks
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 1 year later...
  On 2/1/2017 at 11:27 AM, mikerenief said:
I'm going to have to remove the headlight in order to put on my number plate - there is the light and mapping button mounted on the backside of the headlight. Did any of you TRS owners figure a nice and simple way to move it?
thanks cheers
Expand
 Yeah, unplug it and throw it in the trash, Runs just fine with out it.
