Prototype Posted February 7, 2017 Report Share Posted February 7, 2017 Hi Guys I have honda cg125 engine and friend got bantam frame , there is petrol tank within reach as well .. jap trials wheel with me as well , no forks or front wheel do you think i can build similar bike under 500 Euro .. i can buy bantam engine when budget allows .. bantam easy on pocket ? ideas welcome .. not sure if i go down that path , im not lathe-man , partial spanner man .. got good friend to help Thanks Quote Link to comment Share on other sites More sharing options...
andyrothers Posted February 8, 2017 Report Share Posted February 8, 2017 Not a simple project.. you'll find the Honda engine will be taller and may require major modifications to the frame that will be difficult to put back if you want to install a bantam engine at some point.. carburetor position also will be much higher.. the kickstart will likely hit footrests too.. and once you get the engine to fit you'll have to make an exhaust as nothing else will fit.. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
