chappo Posted February 13, 2017 Report Share Posted February 13, 2017 If you've seen this already in my previous posts I apologise, but didn't want to have it overlooked. It came as a spare with the bike I've just bought that was owned previously by an Engineer, the bracket looks to be a home fabrication. Just curious if having a hard rubber bush between the two plates would not compromise what it was trying to achieve. As the original and aftermarket triangular ones are rigid. 1 Quote Link to comment Share on other sites More sharing options...
model80 Posted February 13, 2017 Report Share Posted February 13, 2017 It's certainly an interesting take on a solution to the head steady problem. I'm (very) far from been an expert rider and yet I manager to break the original forked version after only a few rides. I might drop down to my local engineer's supplies shop and see if they have the rubber bushings to try and make up something similar. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted February 14, 2017 Report Share Posted February 14, 2017 needs to be rigid 1 Quote Link to comment Share on other sites More sharing options...
chappo Posted February 14, 2017 Author Report Share Posted February 14, 2017 Thought that Nigel, sent you a message with the frame number you were asking about. 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted February 14, 2017 Report Share Posted February 14, 2017 (edited) As I said in your other post and Mr Dabster says its got to be ridged Edited March 30, 2017 by bondy Quote Link to comment Share on other sites More sharing options...
