199b Head / Frame bracket.
chappo
If you've seen this already in my previous posts I apologise, but didn't want to have it overlooked.
It came as a spare with the bike I've just bought that was owned previously by an Engineer, the bracket looks to be a home fabrication. Just curious if having a hard rubber bush between the two plates would not compromise what it was trying to achieve.
As the original and aftermarket triangular ones are rigid.
It's certainly an interesting take on a solution to the head steady problem.
I'm (very) far from been an expert rider and yet I manager to break the original forked version after only a few rides. I might drop down to my local engineer's supplies shop and see if they have the rubber bushings to try and make up something similar.
