tydan Posted February 15, 2017 Report Share Posted February 15, 2017 Hi, I'm sure I've read this already somewhere so apologies if it is a repeat. Can you replace the crank seals in situ - i.e. without splitting the cases? I've seen mixed opinions on this...... Quote Link to comment Share on other sites More sharing options...
charlie24 Posted February 15, 2017 Report Share Posted February 15, 2017 Yes you can, done it many times. Quote Link to comment Share on other sites More sharing options...
tydan Posted February 15, 2017 Author Report Share Posted February 15, 2017 Thanks Charlie, any tips on removing the existing ones, I'm conscious of not damaging mating surfaces etc. Quote Link to comment Share on other sites More sharing options...
tony27 Posted February 15, 2017 Report Share Posted February 15, 2017 Self tapping screw wound in gently then pulled out with vice grips. Don't wind it in too far or you risk damaging the bearing Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 15, 2017 Report Share Posted February 15, 2017 https://www.google.co.uk/search?q=camshaft+seal+puller&oq=cam+shart+seal&aqs=chrome.4.69i57j0l15.10516j0j4&sourceid=silk&ie=UTF-8&gws_rd=cr&ei=AMGkWO-uPOaVgAbag42QDQ#gws_rd=cr&imgrc=zuE0a2nJdv7kvM: 1 Quote Link to comment Share on other sites More sharing options...
