The correct software ??
99techno
Hi guys, one for you tech experts.
I have the twin map PTB on my 300rr and wanted to play around with some maps, the software I have is the HRC RTL 260F, does anyone know if this is correct for the job and if not, which one is right and where to get it?
Cheers!
P.S all you old farts with your links to ordnance survey map sites and  "just learn to ride" I've heard it all before!
don't know for definite but would imagine same.
Have you tried to communicate with the PTB on RR.
The earlier software needed to run on old computer/laptop a (32bit??) also used serial port not USB.
You can upload the map from the PTB without erasing it so plug in see. I believe you can only read the last map that was installed - so for twin map you will only get last one back out regardless of the switch setting
Last question, I've read the PTB last night and from what I can gather installed a different map but nowhere does it give me the option of choosing which mode to write? How do I select which mode to write? Is it the switch on the handle bar?
I'm sure if you have twin map software there is a page or option at the bottom to download to map 1, map, 2 or both.
(page 23 in the manual)
TH map mode select
• When select Mode1 & Mode2, map change will be reflected in both Mode1
and Mode2.
• When select Mode1, map change will be reflected in Mode1. Mode2 map
stays base map.
• When select Mode2, map change will be reflected in Mode2. Mode1 map
stays base map.
Ignition map mode select
and Mode2.
stays base map.
stays base map.
http://www.montesa4rt.nl/
if you haven't got a manual -the Tl260 software seems better than the earlier versions
Graduate 1st Class, D Trump school of tact and decorum.
